sunglass holder
Old May 20, 2010 | 02:14 PM
Ian's Avatar
Ian
Default sunglass holder
Anyone know if I can add a sunglass holder on a 09 Outlander XLS ?
Old May 20, 2010 | 07:02 PM
jsrd's Avatar
Ian, at least I can confirm that isn't possible fit it on Outies with sunroof, and OEM sunglass holder is compatible to 07-10 Outies (without sunroof, of course)
Saludos. . .
Old May 20, 2010 | 07:41 PM
alopandur's Avatar
I have added it by cutting the headliner without removing it. If you remove the dome light assembly and stick your fingers through the hole towards the back of the car, on the upper surface of the headliner will be groves easily touchable, marking the outlines for cutting. I determined the corners, punched nails from the space between the roof and the headliner and towards the cabin and then used the serrated knife to cut it from inside the cabin. Use shorter knife to avoid hitting the metal roof while cutting. Not sure if I missed my line or the markings were wrong, but mu opening was some 2-3mm larger, not a big deal, however it would be better if the fit was snugger. Works great... Mine is Outlander 2008
Old May 20, 2010 | 10:41 PM
Ian's Avatar
Ian
Saludos. . .
OK Thanks jsrd
Old May 28, 2010 | 02:35 PM
mtryan0505's Avatar
Where did you find the sunglass holder? I'd like to put one in my car.
Old May 28, 2010 | 03:43 PM
jsrd's Avatar
Mitsugurl
Jul 22, 2018 08:51 PM
txiko
Oct 15, 2012 07:03 PM
ShortyRider
Dec 31, 2009 09:09 PM
5Tizzle
Apr 12, 2006 11:59 AM
97redEclipse0010
Apr 13, 2005 01:12 AM
