Timing belt change
Old Nov 20, 2018 | 02:43 PM
dirt.devil's Avatar
Default Timing belt change
My 2012 Outlander is over 80k miles, checked the user manual and it says that the timing belt should be replaced at 105k. Should I wait until I get close to 105 or should I bite the bullet and do it early to avoid problems?
Old Nov 20, 2018 | 02:59 PM
copyboy311's Avatar
No need to do it early. It's an expensive job, and 105k seems like a fairly conservative interval for the belts they make today (likely Kevlar). I did mine at 105k with no issues, so I see no reason to not trust the recommended interval and spend the money before it's time.
Old Nov 26, 2018 | 02:20 PM
binzd's Avatar
same here, I changed my belt at 110k miles and it looked brand new (but mine never sees harsh weather) I couldn't tell the difference between the new one except by the markings
Old Nov 26, 2018 | 02:49 PM
dirt.devil's Avatar
Thanks guys, had one break on a Subaru so trying not to repeat that experience.
Old Nov 26, 2018 | 04:16 PM
AWCAWD's Avatar
One small detail that might have coused your worries: Subarus have rubber timing belts that require more frequent replacements and more prone to damages. Mitsubishi's ( 2.0 L, 2.4 L gasoline engines, but 3.0 L V6 has a belt, please see the next post for clarification) on the other hand have timing chains. You should follow the owner's manual for replacement and should be fine.
Old Nov 26, 2018 | 04:21 PM
binzd's Avatar
the 6B31 (3.0V6 MIVEC) uses a kevlar timing belt
Old Nov 26, 2018 | 10:53 PM
ccernst's Avatar
this is correct. My first change at 110k miles, there was some fraying on edges, but teeth in great shape...no cracks. Replaced with Goodyear gatorback belts. At 220k miles did it again, belts in great shape. Goodyear sold gatorback line to continental....so replaced with continedntals....fingers crossed it goes to 330k miles. At 230k miles now.
Old Nov 27, 2018 | 12:25 AM
SERPENTOR's Avatar
Ccernst did you replace the Water pump everytime you do the belt replacement?
Old Nov 27, 2018 | 08:39 AM
AWCAWD's Avatar
Thank you for the correction.
Old Nov 27, 2018 | 01:24 PM
dirt.devil's Avatar
mine is the 4cyl Outlander, believe is a belt.
