Timing Belt Kit and Water Pump Kit
Old Jan 15, 2020 | 10:41 PM
SERPENTOR's Avatar
Default Timing Belt Kit and Water Pump Kit
Replacing Timing Belt and Water Pump Kit and getting a Coolant Leak fixed how much should it cost for a 2008 Mitsubishi Outlander XLS V6? Parts + Labor?
Old Jan 16, 2020 | 02:22 PM
SERPENTOR's Avatar
Which company makes better timing belt and water pump kits, Gates or Asin?
Old Jan 16, 2020 | 02:57 PM
SERPENTOR's Avatar
The coolant Leak is my radiator, what is the best brand to go with that offers the best quality radiator for a 2008 Mitsubishi Outlander XLS V6?
Old Jan 17, 2020 | 02:17 PM
ccernst's Avatar
Honestly, I would not go with a kit....just get the parts.
Hitachi is oem water pump, 70 bucks on rock auto. I changed my pump at 200k miles and was in perfect condition. I had changed my coolant at 75k miles with peak global lifetime fluid.
first time I did timing belt, I used a Goodyear gatorback. That worked really well....held up better than oem. Goodyear sold belt line to continental, so 2nd time I did belts, I went with them. When doing timing belt, do the accessory belt too....it has to come off anyway and costs like 20 bucks.
Old Jan 17, 2020 | 05:57 PM
SERPENTOR's Avatar
Thank you bro!
Old Jan 18, 2020 | 04:16 PM
ccernst's Avatar
Also, do change the timing belt tensioner
Old Jan 18, 2020 | 05:05 PM
SERPENTOR's Avatar
They discovered my coolant Leak was coming from the radiator so I told them to replace it with a new Denso radiator.
Old Jan 18, 2020 | 05:51 PM
Tiger01's Avatar
I have a 2009 Outlander and replaced both the timing belt & water pump last year
parts and labour came to almost $1400 and that is in Canadian dollars
Old Jan 18, 2020 | 06:16 PM
SERPENTOR's Avatar
That's Alot of money do you know which parts they used?
Old Jan 18, 2020 | 06:40 PM
Tiger01's Avatar
yes I had them use OEM parts
