Tires crack at the tread
Hi all I have a 2016 Outlander GT and I bought it brand new a year and a half ago and only have 14000 miles and the tread is cracking like it is dry rot. Has others have this issue? If so how did you get your tires replaced under the warranty.
Thanks for any help!
Serpentor,
I did go to the dealer first then they told me to go to a auth tire dealer for the Toyo tires I was told no go when you drive it off the lot they have nothing to do with it!
True...the tires on a new vehicle are covered under a seperate warranty from the tire maker....just call the head office of the manufacturer and they will direct you acordingly. There should have been some documentation regarding tire warranty when you purchased the vehicle. Best of Luck
newoutlanderfan
Jun 19, 2011 01:06 AM
