Transfer maps from SD to HD, is it possible?
Old Oct 15, 2013 | 03:53 AM
jsrd's Avatar
Default Transfer maps from SD to HD, is it possible?
Mitsubishi Mexico finally offers MMCS (N-11 version) as standard equipment on top models, and I see the possibility to obtain the map of Mexico in my MMCS (N-01 version) purchased in the United States, so the question is, will it be possible to transfer maps from SD to HD, someone has an idea about this?
Old Oct 15, 2013 | 09:04 AM
Vadimus's Avatar
According to our Russian colleagues already enjoying new Outlander (and N11 MMCS as well) for over 2 years there's no easy way to read those SD cards. SD security is not supported even under Linux, you need a specialized MC to do this. Unlock key is required as well, not sure if it was already grabbed.
Old Oct 15, 2013 | 11:01 AM
jsrd's Avatar
Thanks for your answer amigo. My idea was to remove the HD and unlock it, and take the maps of the SD, which I supposed are in the same format as in our MMCS, copied to HD, and that that would be enough. I will try to obtain a copy of the SD, or even Mitsubishi USA may offer an DVD maps upgrade disc that already includes Mexico, I hope someone can confirm this last thing...
I'm crossing my fingers to get these working in my MMCS
Old Oct 15, 2013 | 08:22 PM
Vadimus's Avatar
On the other hand, once you enter the proper unlock key, the maps format is still the same.
So all we need is (hopefully a bit of) patience
Old Oct 16, 2013 | 10:05 AM
jsrd's Avatar
patience and get a copy of the maps .... so keep fingers crossed
Old Oct 16, 2013 | 10:18 AM
jsrd's Avatar
someone in the U.S. or Canada can confirm if SD card includes Mexico maps??? could share the part number of the SD card maps???
Old Oct 16, 2013 | 02:42 PM
jsrd's Avatar
Part numbers for Mexico:
8750A387 - SD card with maps
8750A338 - Backup navigation disc
can anyone confirm in USA or Canada if it is the same part numbers???
seetherage
Apr 28, 2008 06:56 AM
ZuluXls
Aug 19, 2007 10:34 PM
chelsel
Feb 13, 2007 11:32 PM
