Transmission flush AFT strainer filter location
Old 09-16-2017 | 09:25 AM
Careful's Avatar
Default Transmission flush AFT strainer filter location found
For those doing a transmission flush and are wondering where the ATF strainer is, see the below screen shot taken from page 32 of Mitsubishi manual 23B "Automatic Transaxle Overhaul" . It's bolted to the ATF pump which itself is bolted inside the transmission. You have to remove the transmission and take it apart to get to the strainer/ filter. My advice would be to disregard changing it during a normal AFT flush.
Edited to add: This is for a 2007 with the V6.
Old 09-18-2017 | 11:28 AM
binzd's Avatar
I 2nd that motion, no way getting into that. Just do the proper drain and fill procedure from the trans cooler lines and keep that fluid healthy to prevent the shavings in the first place
Old 10-08-2017 | 10:00 AM
Georgeandkira's Avatar
Default 2011 w/4 cyl.
Hello, I do not know if this is of any help as it is from my experience a few weeks ago.
I helped a friend do a transmission drain and fill on his 2011.
I bought a pan gasket and a strainer/pick-up.
The fluid, at 90K, was as dark as the darkest (industrial grade) maple syrup.
The pan came off easily.
The filter removed with 2 bolts. It was a stainless steel mesh.
I don't know if this is what you're dealing with. Kira
Old 10-09-2017 | 11:57 AM
ccernst's Avatar
George, you have a completely different transmission than Careful does. Even the procedure to change fluid is different.
maggiesmim
05-20-2015 08:54 AM
maggiesmim
02-26-2015 08:33 AM
dublup50
11-15-2013 01:01 PM
MikeDiPaolo
11-01-2012 12:09 PM
Ahyc
05-05-2009 07:12 PM
Quick Reply: Transmission flush AFT strainer filter location
