Transmission secondary pressure low
Hello
i have a 2009 outlander with chassis code DBA CW5W 5402238 FWD with the 4B12 engine.
At mileage 160k i heard a whining noise from underneath which increased with speed and had it checked out and it turned out to be the transmission cooler. Had to remove all the cooling components and the gearbox which was contaminated with water.
i replaced the friction plates and cleaned the gearbox and got a new oem trans cooler and filter ans cleaned the valve body and put it back in. It started fine but the vehicle wouldnt move an inch in gear. The paddle shifts or the reverse didnt work and the scan showed a error code p0868 secondary pressure low. I replaced the pressure sensor and checked all the solenoids and the wiring upto the main harness and everything checks out fine but still the same error code shows up and the vehicle doesnt move. When you clear the code and start it back up it revs up just fine but when you put it in gear the car wont move and it wont rev as well.
please help! I dnt know what else to check. Is it a faulty torque convertor or the TCM or is it the transmission pump fault?
