code throw 36
Old Oct 27, 2007 | 09:06 PM
itsme71190's Avatar
Default code throw 36
ight. before i go to get a diagnosis i did the code check with the key.
i threw a code-36-which is Pair Solenoid Circuit-M/T
how do i go about fixing this??
Old Oct 28, 2007 | 02:03 PM
dsm1990gsx's Avatar
Default RE: code throw 36
ORIGINAL: itsme71190
What is the year of the car I have access to alldtata and can check out the codes are and what can cause it.
Old Oct 28, 2007 | 04:39 PM
itsme71190's Avatar
95gs
Old Oct 28, 2007 | 04:56 PM
dsm1990gsx's Avatar
This what I got of alldata and doesnt really make sense since u have a manual transmission. This is what it says:
Code 36- Fault immediatley after a shift, probable cause is internal tranaxle problem.
Thats code 36 under transmission, code 36 for the pcm is map sensor voltage too low. So idk what to tell ya.
Old Oct 28, 2007 | 05:11 PM
dsm1990gsx's Avatar
How did u get the dtc, w/mil pulses or scan tool? Just want to be sure.
Old Oct 28, 2007 | 09:21 PM
itsme71190's Avatar
lol. well i did take the transaxles off when i replaced the clutch. but i had no problem until i rebuild the head of the motor
Old Oct 29, 2007 | 06:44 AM
ORIGINAL: dsm1990gsx
he said he did the key dance to get it
Old Oct 29, 2007 | 08:05 AM
dsm1990gsx's Avatar
Ok then ob1 is confusing w/ all the different ways to get codes, ok w/ mil pulses code 36 is for pulsed secondary air injection solenoid. They're a few difernt things that could cause this code
open or shorted control circuit
open or fused ignition switch output circuit
open or shorted solenoid coil
failed pcm
Sry for the previous posts there are a lot of different senarios abt pulling dtc's and on alldtatapro.com its confusing for obd1 cars.
Old Oct 30, 2007 | 08:57 AM
itsme71190's Avatar
ok thanks
Lancergirl
Feb 9, 2006 03:08 AM
anko_kun
Jan 23, 2006 09:01 PM
minping
Jan 6, 2005 09:53 AM
Prototype_fabs
Aug 15, 2004 03:27 AM
Prototype_fabs
Mar 22, 2004 01:41 AM
