OBD PO456 & PO135
Old Oct 29, 2007 | 08:54 PM
robertwa's Avatar
Default OBD PO456 & PO135
Hi, new to this forum, great resource here!
I have a 2003 eclipse which is showing fault codes PO135 and PO 456 (front O2 sensor and evap emisions small leak). Before I start attacking the car with wrenches, is there anything I should be looking for? Could the two faults be related? I looked under the hood and the front O2 sensor looks easy to change, but I don't want to change itif this fault is being flagged by the other fault.
For an evap leak, do I need to check all the hoses for leaks or loose connections? I am not even sure where the evap canister is located??
Thanks for any help
Old Oct 29, 2007 | 09:04 PM
dsm1990gsx's Avatar
Default RE: OBD PO456 & PO135
I doubt they are related, replace that 02 sensor and make sure the gas cap is fully seated.
Old Oct 30, 2007 | 12:41 AM
sk8dudety's Avatar
wait, is that eclipse a v6? cause it might have 2 o2 sensors... my mom's taurus threw the same code, and it wound up being the second 02 on the rear exhaust mani... make sure ur replace the right one, that is, if there is two
Old Oct 30, 2007 | 07:44 AM
That code is listed as Bank 1 sensor 1. Probably the first one. I would just replace it and hopefully that will get rid of both
Old Oct 30, 2007 | 03:01 PM
dsm1990gsx's Avatar
An o2 sensor will not cause an evap code. Since p0442 is a small evap leak dont worry abt it now, just replace the o2 sensor and clear the code and see if the cel comes back on.
Old Oct 30, 2007 | 11:42 PM
robertwa's Avatar
Thanks for the replies. I will change the O2 sensor this weekend and see what happens.
Gsteclipse22
May 6, 2008 08:05 PM
Stryker
Sep 16, 2007 08:36 PM
rvelez123
May 9, 2005 07:40 PM
Xit40
Jan 21, 2005 06:04 PM
davesrave
Dec 21, 2004 04:27 PM
