trouble codes p0335 and p0340, pls help
hi , i ve got 03 outlander, yesterday i couldn't start it and got two codes P0335 - Crankshaft Position Sensor A Circuit Malfunction and P0340 - Camshaft Position Sensor Circuit Malfunction
i tried reseting ecu and did clean all the electrical wiring on those sensors. Really suspicious that two sensors could go bad at the same time, but who knows.
still can't start, dont know what to do, any suggested would be really appreasiated, it is 2.4L 194000km
Thank you in advance
i have a Mitsubishi colt ralliart but it wont start,well they said that the ecu is working,change both crank n cam sensors,check tru the wiring for any open circuit that part is k.the problem is that current is not coming down to the plugs.each time we put the diagnosis on it said po340 n there is a new cam sensor on it,so i am really confuse,dnt know what other options leave.really need your advise plz n thanks.
