trouble codes p0335 and p0340, pls help
Old Sep 19, 2010 | 10:16 PM
slavao's Avatar
Default trouble codes p0335 and p0340, pls help
hi , i ve got 03 outlander, yesterday i couldn't start it and got two codes P0335 - Crankshaft Position Sensor A Circuit Malfunction and P0340 - Camshaft Position Sensor Circuit Malfunction
i tried reseting ecu and did clean all the electrical wiring on those sensors. Really suspicious that two sensors could go bad at the same time, but who knows.
still can't start, dont know what to do, any suggested would be really appreasiated, it is 2.4L 194000km
Thank you in advance
Old Sep 20, 2010 | 07:13 PM
slavao's Avatar
hi, got the problem figured out, my timing belt is gone. Hopefully didn't do much damage.
Old Feb 2, 2012 | 06:55 PM
Winston's Avatar
i have a Mitsubishi colt ralliart but it wont start,well they said that the ecu is working,change both crank n cam sensors,check tru the wiring for any open circuit that part is k.the problem is that current is not coming down to the plugs.each time we put the diagnosis on it said po340 n there is a new cam sensor on it,so i am really confuse,dnt know what other options leave.really need your advise plz n thanks.
kieferg933
Aug 9, 2017 12:49 AM
CaptainDon
Nov 16, 2013 02:43 PM
Shepard69
May 20, 2011 08:50 PM
rascosss
Oct 28, 2010 07:51 AM
Rob
Jan 8, 2008 05:58 PM
