Turn off ignition but keep power on.
Old Sep 6, 2015 | 09:48 PM
GOLDshark's Avatar
Default Turn off ignition but keep power on.
Tried searching for this but didn't have any luck.
I recently purchased the MY16 Outlander Exceed and have been relatively happy with it. The connectivity and usable of the entertainment system is a little clunky vs. a Falcon which i previously owned which is probably my only criticism.
One thing i haven't been able to work out how to do is shut off the ignition whilst leaving the power on, ie. radio etc. For instance if you arrive to your destination and wish to continue to listen to the radio or finish a phone call you must leave the ignition on otherwise you need to power back on to listen to the radio and reconnect the Bluetooth which is quite frustrating.
Hoping i am missing something quite simple here as it seems like an obvious thing to do???
Old Sep 7, 2015 | 10:02 AM
Guyfromhe's Avatar
Try putting it in neutral when shutting the engine off..might work..Also you can ask the dealer sometimes they can program how those buttons work...
Old Sep 10, 2015 | 03:01 AM
GOLDshark's Avatar
You got it Guyfromhe, it worked! thank you so much.
Old Sep 11, 2015 | 12:19 PM
Guyfromhe's Avatar
Glad it worked. Wasn't sure if this applied to all cars. This is why I prefer the turn to start vs the push to start.
Old Sep 11, 2015 | 01:17 PM
Copper penny's Avatar
Smile
Thanks for the post!!! That's good to know I'm new to the Outlander SE myself. Glad to hear from other Outlander owners
Old Nov 8, 2020 | 01:55 PM
skdaddle's Avatar
Putting it in Neutral and shutting off the engine did not work in our 2017 Outlander but dropping it into Drive with the emergency brake set and shutting it off did the trick. The radio continued to play for the duration of cleaning and vacuuming the inside of the vehicle. After about 45 minutes we put the vehicle back into Park and shut the engine off. Hope this works for someone out there, surprised this is not in the Owner's Manual unless there are safety reasons with the manufacturer for excluding it. Good luck with your model!
Old Nov 28, 2020 | 02:07 PM
Richard Hadley's Avatar
Default Response
Don't put it in to neutral when engine of... It confuses electrics.. I did this and had to wait 2 hours to get engine stafted
bcolins
22
Jun 27, 2018 08:19 AM
azsungal77
May 2, 2012 04:00 PM
allallyouyou
Feb 12, 2012 11:13 PM
siraerich
May 14, 2007 11:16 AM
dornstar
May 22, 2006 04:58 PM
