Turn Signal Flasher Relay?
hey all!
I just recently bought a brand new 2011 Outlander XLS...I installed some PUTCO LED turn signals for the front and rear turn signals. They both are "hyperflashing" (blinking way too fast)
I heard that I can just replace the flasher relay with one made for LEDs (like a TRIDOn EP34) but I can not seem to locate the darn stock flasher AT ALL! I know it is under the dash, because I can hear it clicking when the hazards are on...but I can't pinpoint it for the life of me! does anyone know exactly where it is at? or have a picture where it is at?
thanks for your help!
I had the same problem with my '07. I had removed the entire gauge assembly from the dash to locate the "flasher" unit. The sound appears to be coming from inside the speedo and tach assembly...it must be a component on a circuit board and not a traditional plug-in unit. I cold not find the location on the shop manual wiring diagram, but I'm not as smart as I look. I noticed the turn signals hyper flashed, but not the hazards. Probably due to the combined load from the 4 leds being on at the same time. I ended up installing load resistors on all four leds and that solved the problem. Hope this helps.
Hi all,
I have a 2010 Mitsubishi Outlander. When I attach a trailer, the indictors on both the vehicle and trailer don't work. All wiring on the trailer is correct and properly earthed. Any suggestions?
Emrys Qin
Sep 29, 2020 03:45 AM
mjmdotorg
Jun 14, 2016 01:22 AM
CMS062407
Dec 1, 2012 12:34 AM
