Turn Signal Issue - 3 flashes
Old Jan 31, 2008 | 11:27 AM
Cuffy's Avatar
Default Turn Signal Issue - 3 flashes
Has anyone tried the 3-flash turn signal change on the MMCS?
I don't know if it is because the car is still new and the turn signal stalk is not broken in yet, but when i push the lever slightly (as indicated) it doesn't alwaysactivate the 3-flash setting. Sometimes it does and sometimes it doesn't. Now when i push it iend up pushing it too hard so that it will engage andjust end up pushingit all the way.
Just curious.
Old Jan 31, 2008 | 11:38 AM
ronwill's Avatar
Default RE: Turn Signal Issue - 3 flashes
I find the same thing happens with mine which is 12 months old now so it is not just a case of the switch 'breaking in'.
I find that a light quick flick of the switch does it most times ( but not always!!)
Happy 'Outings' !!!
Ron
Old Jan 31, 2008 | 01:07 PM
smily157's Avatar
When I got the car, I thought that it wasa cool feature and activated it, but I have come to realize that it is more of an annoyance because it does not always work. Sometimes when I want to use it I either end up not pushing hard enough, or pushing too hard and turning the signal full on. And then other times when I accidentally brush up against it it goes off. I have decided to turn it off and just signal the old fashioned way, it was a good thought though
Old Jan 31, 2008 | 01:36 PM
tcp's Avatar
tcp
it takes some getting used to. It works great for me. The biggest problem is when i drive our other vehicle, i try to change lanes using this method and it doesn't have this feature...which means I become one of those non-signalling A$$holes I curse at.
Old Jan 31, 2008 | 01:47 PM
Cuffy's Avatar
ORIGINAL: tcp
Nice! I hate those punks.
If i could i would have made it flash 4 or 5 times even, because 3 just doesn't seem to be long enough. I guess i may just diable it andrevert back tothe old way. At least now i know i'm not the only one that feels that way.
Old Jan 31, 2008 | 01:59 PM
tdford's Avatar
Works great for me and love it. On my old car I would always just hold the stalk to the part where it wouldnt lock, signals would flash for as long as I held it, and when I let go it stops. So its great that I can just flick it once and get 3 flashes, which is enough.
I didnt have to "break" it in though. Just like last car, just flick it enough where you feel the resistance of it about to lock, then let go...
Old Jan 31, 2008 | 03:08 PM
Sergy's Avatar
Who don't like "3 time flash" feature can easily disable it: every dealercan re-programm Outie's computer.
Old Jan 31, 2008 | 05:59 PM
maharajah's Avatar
Works perfectly every time on my 2007 non-MMCS Outlander.
Old Jan 31, 2008 | 07:20 PM
biscuit's Avatar
I didn't use it at first, but recently I've been using it more and more. I would like to be able to set it so it blinks 5 times.
Old Jan 31, 2008 | 07:35 PM
Fisherman's Avatar
I think is that the signal is too easily fully engaged. Just a little too hard of a tap and I have turned the signal all the way on. It appears to require a more refined touch than my club hands have, to make it work consistantly!
