Tweeter Install
Old Nov 10, 2006 | 12:41 AM
GTAlander's Avatar
Default RE: Tweeter Install
Here ya go (if you don't have it already)
- Open up the front doors and lower the windows
- You'll see some triangular shaped plastic covers
where the interior trim meets the window.
- You need to pry off the trim pieces. Use a flat
screwdriver and protect the edges with a soft cloth.
- Just pry it out - it will snap out after enough
force is applied
- When the covers are off, the factory wiring is right
there.
- The rest of the install depends on the tweeters you
purchased.
- I cut off the factory plug and attached the solid
coloured wire to positive and the wire with the black
stripe to negative.
- After mounting the tweeter, make sure the trim cover
still fits in its place and snap it back on.
- There are no cross-overs to worry about.
Good luck
Old Jan 9, 2007 | 11:19 PM
Simple Red's Avatar
Ok, so I finally got tweeters, and hooked them up like everyone said, and they work. My question is: How did everyone mount the tweeters w/o stock hardware? Also, how does the stock hardware hold the tweeters in place? I was in a hurry, so I hot glued them to the grilles by the speaker surround. It has worked so far, but wonder what will happen during the summer, so I am interested in a stock setup. Help?
Old Jan 10, 2007 | 03:32 PM
JMC's Avatar
JMC
Yeah...I don't the hot glue is gonna work for long.
Old Jan 11, 2007 | 02:59 AM
fba0861's Avatar
If you can't find the stock setup, take a look at this old post from the past. Done by chinna_n.
Tide cans make good tweeter mounts I guess.
https://mitsubishiforum.com/m_1611/mpage_2/key_/tm.htm
I haven't done mine yet. Poor cash flow.
[IMG]local://upfiles/10246/49CAF1F1B8394208AA4317308DE769F3.jpg[/IMG]
Old Jan 11, 2007 | 03:03 AM
hot glue will work fine....
korinkoj1
Mar 20, 2016 10:04 AM
Audioquest
Mar 27, 2012 11:44 PM
steph1693
Sep 25, 2009 01:33 PM
hammer2much
Jun 10, 2008 10:51 PM
Scubba.steve
Feb 9, 2008 10:11 PM
