Unable to access menu screen in Info Center
Old Dec 20, 2007 | 04:51 PM
shinoix's Avatar
Default Unable to access menu screen in Info Center
Anyone else have this problem? I was reading the manual and it allows you to change the temperature settings from F to C, or vice versa, as well as fuel consumption from Miles to KM or vice versa as well.
It says that by scrolling through the screens, you should be able to access the menu screen. Holding down the info button when at the menu screen should give you options to change.
Mine doesn't get to the menu screen. I scroll through the two trip odometers, service screen, temperature, fuel consumption, etc...then back to the trip odometer without even seeing a menu screen to change settings.
Any help?
Old Dec 20, 2007 | 05:33 PM
chowc's Avatar
Default RE: Unable to access menu screen in Info Center
I have the same issue.....it does not do what the manual states.
Old Dec 20, 2007 | 06:57 PM
oldpapa1949's Avatar
I think its
Car on, Park, Brake up and hold for 10 secs
Old
Old Dec 21, 2007 | 04:24 AM
shinoix's Avatar
ORIGINAL: oldpapa1949
I think its
Old
Are you serious? Put the parking brake on and hold the info button for 10 seconds? It makes NO mention of that anywhere in the manual.
Old Dec 21, 2007 | 06:58 AM
roach's Avatar
What I did to get the menu screen is ignition on but motor off handbrake on and you scroll until you get to the setting screen hold 10sec and your in I did that to change my Fuel consumption monitor to manual the other day !
Old Dec 21, 2007 | 11:19 AM
tdford's Avatar
Im pretty sure those options are under the "Set" button. Can change the time, display, and units...
Old Dec 21, 2007 | 02:21 PM
shinoix's Avatar
ORIGINAL: tdford
Where is the "set" button? The time is changed on the radio display, not the info button or screen.
Old Dec 22, 2007 | 12:28 PM
tdford's Avatar
ORIGINAL: shinoix
Ok, so I looked at your post closer now and figured that you do NOT have the nav system right? So if you dont, this information doesnt help. If you do, it does.
On the MMCS there is a INFO and SET button. SET is the lower left button. That brings you to a menu. Then select "System", which takes you to where you can change the units, clock, all kinds of things to chirping when you lock the outtie, to setting the rear wiper.
If you dont have the MMCS, you're screwed..... no will have to look in the manual to find the combo of button pushes to figure all that out...
Old Dec 22, 2007 | 10:41 PM
armymen's Avatar
i have the 2008 and i cant go to change setting too.
Old Dec 23, 2007 | 04:40 AM
Malu's Avatar
In order to reach the setting window (non-mmcs, Outlander 2008) :
Engine turned on or at least switch in On position.
Car standing still, handbrake engaged.
Gearbox in neutral (I suppose park is applicable for people with automatics)
Cycle through info window until I get to settings menu
Press and hold for two seconds to enter
Hope this works - good luck!
