Under-Hood LED Work Light Installed
Just some shameless self promotion
I added a waterproof LED strip from V-LED's to the under-side of the hood. This is not just some ghetto underglow, it's wired into the OEM hood release and only comes on when the hood is popped. I don't go to car shows or anything, so this is just in case of a roadside emergency or other night time under-hood work.
The "glare" lines you see are coming straight off the LED strip, perpendicular to the flat spot on the underside of the hood. As you can see, they point perfectly down at the engine bay:
(sorry for the crappy pic):
Wiring comes off the LED strip and goes into the hood "ducting" I suppose it might be described as, just the hollow section between the hood skeleton and the hood skin:
it comes out of the hood right near the hinge:
and runs along the fender. I still have a little more tidying up to do with the wires, as of now there's only a couple "clear" zip-ties holding it there:
The OEM hood position sensor is wired weird, I tapped into a silver wire, which I assumed was the HOT side because it connected to the red wire that went into the pressure switch, but it was not. The neg. of the LED strip tapped into the pressure switch and the hot side goes straight to the battery. The light goes off when the hood is closed and turns on when it opens, so whatever.
Just to really emphasize how bright it is, NONE of the pictures, including neither the top picture, nor this one were taken with the flash (in the dark parking lot pictured above):
Yes, I believe they are.
6K WHITE EXTERIOR WATERPROOF LED STRIP LIGHTS - Exterior - Strip Lights
I got the 24" strip, so with free shipping (when I ordered it) and I already had the wire I'm very happy with the outcome for only $12 invested!
Mitsubishi Lancer 08 09 ES GTS de Front JDM Strut Bar | eBay
It has been pretty much confirmed that any strut bar designed for an 08+ Lancer will work for the Outlander Sport. Various members on evoM have tried this one as well and various other bars and they all have worked so far. I can't vouch for the full size Outlander though.
That one I posted above is pretty inexpensive, but it actually made a noticeable improvement. Still no race car though lol
Thanks! It was a little bit of a pain fishing the wire, but the passage itself is clear of obstruction, it just takes some patience and finesse to get it out the little hole. I ran the wire half-way & out the hole for the hood prop, then did the second half from there.
Yup! Same here!
Thanks! Post some pics of yours when you get it done!
theiss2200
Sep 12, 2019 08:07 PM
makaveli
May 27, 2012 03:38 PM
