USB port for factory headunit?
Old Apr 4, 2010 | 05:55 AM
Redeye's Avatar
But when i look at this Rockfordfosgate converter at least i get the impression that i could disconnect the cables running to my AUX-outlet in the armrest and instead connect this one, just cut the RCA-konnectors off (since i´m guessing that there is just a socket at the back of the headunit)? All i need then is to get power or am i missing something?
I´m also considering replacing the headunit. Is this the headunit you are considering?
Old Apr 4, 2010 | 07:10 AM
rene's Avatar
Wink alternative solution
I buy this product and it works very well for 39,99 $canadian from bestbuy
The url : http://us.kensington.com/html/14492.html
Liquidaux dor ipod and iphone
the product will charged and control your ipod.
you will probably have a noise in the speaker
in case, the compagny will send you a ground loop isolator to eliminate the buzz sound.
because this connection is plug into the ipod you dont have to take care of the volume of the ipod.
the little remote (fixed on the steering) work very well
Old Feb 13, 2015 | 03:12 PM
Maverick78's Avatar
Hi..I have a Mitsu Outlander 2010, with RCA audio input (center arm rest), no navi nor FUSE but has handsfree bluetooth module (8785A002), Rockfordfosgate 6 cd changer unit. I would like to install a USB connection for playing music from ipod, iphone and also for charging. Any ideas or link ? Do i have to buy a new bluetooth adapter with usb interface or 8785A002 is compatible. Pls help.
Old Feb 16, 2015 | 01:13 PM
Vadimus's Avatar
I've upgraded my non-FUSE audio to FUSE one.
8785A002 is not compatible.
8785A025 or newer is. For 2010+ MY most likely all you need is a new BT unit and USB cable, existing 2010 radio might already support it.
Old Feb 17, 2015 | 06:45 AM
Maverick78's Avatar
Thanks for the reply, I will check for some alternative...
milliesdad
Mar 16, 2013 10:21 AM
milliesdad
Oct 29, 2012 06:42 PM
Rudeytwotone
Jan 8, 2012 04:04 AM
supermanu_l
Apr 8, 2011 02:08 PM
p6793026
Sep 23, 2008 02:38 AM
