Vibrating noise
Old Jan 13, 2012 | 04:25 PM
mcam's Avatar
Default Vibrating noise
I have a 2007 Outlander XLS. When you put the car in gear and accelarate I hear a metal vibrating noise from under the car. It also happens when you come to a stop. Doesn't happen continously but more frequently.
Any clue as where this noise is coming from.
Old Jan 13, 2012 | 08:08 PM
ShortyRider's Avatar
Does it sound like a piece of sheet metal hitting against the car or body or another piece of metal? Sounds like an exhaust heat shield has came loose and will vibrate when the car is under acceleration, therefore exhaust gas flow faster and the heat shield will hit against the exhaust itself. If you can, just look under your car, (Outlander is kinda tall, so you can see it quite good), then find the piece of loose sheet metal. Just rip it out, you probably dont need it for normal daily drivers. I removed mine because it was doing the same thing.
Old Jan 14, 2012 | 03:44 PM
mcam's Avatar
It doesn't sound like hitting the car or body. Just like the metal sound grrrr. I can feel it coming from underneath. It happens only when you come to a stop and also when you accelerate.
Old Jan 16, 2012 | 07:34 PM
benshepherd's Avatar
Have you tried looking under the car and checking nothing is loose - probably a good place to start. As already mentioned, heat shields on exhaust commonly rattle. Just pull it off if that is the cause.
Old Jan 18, 2012 | 07:22 PM
mcam's Avatar
Yes it was the shield. I got it out and the noise stopped. Thanks for all the inputs.
Old Sep 9, 2012 | 11:19 PM
ccernst's Avatar
heh, had this happen today. Wife was saying for the past week that there was a rattle, but could never reproduce it.
bent the shield a bit away from the pipe...no more rattle. when the other side rusts apart, then the shield is no longer my problem!
klas
Oct 8, 2012 05:18 PM
pwitoslaw
Mar 28, 2009 01:09 PM
elnerdo
Nov 27, 2008 10:16 AM
vbrown0629
Mar 2, 2006 06:34 PM
jneumann
Dec 20, 2005 05:39 AM
