well i think I have a project in the works
Old Oct 12, 2006 | 07:38 PM
Punisher's Avatar
Default well i think I have a project in the works
a friend of mine who works heavily with eclipses is considering a joint venture with me to ad a turbo to my outtie.
now, i wouldnt be doing this normally, but hes giving me his parts very cheap and he has a pretty good knowledge of the engine.
so i guess stay tuned and we'll see what develops.
also, most likely if/when I do get his parts, I wont be able to do any installs until spring, however this will be more like a research thread should this project fly.
Old Oct 13, 2006 | 12:30 AM
dirtwagon's Avatar
Default RE: well i think I have a project in the works
Good luck on the turbo setup- it should work fine if it's the same 4G63 or 4G69. You will need to custom fab an exhaust and probably program the ECU to manage the additional fuel needed. So you will be doing injectors, fuel pump, etc or will it be a mild boost? Is it a stock GST setup tou are going to run?
Gran Nismo
Sep 2, 2015 01:12 PM
963000gtvr4
Feb 1, 2011 09:34 PM
PappiDread6
Nov 24, 2008 08:31 AM
4never
Apr 10, 2008 08:19 AM
2nd g eclipse gst
Mar 26, 2008 11:28 AM
