Wind Deflectors
Old May 27, 2007 | 06:05 AM
zontarh's Avatar
Default Wind Deflectors
I finally got around to fitting my wind deflectors last night.
It's an easy enough job, apart from inserting the clips (If anyone thinks they can get the clips in without the window rubber removed forget it), and remember the clip right at the front on the front door deflector is slightly different, easily overlooked even tho they come in a seperate bag.
The windows have to be down and the rubbers pulled out and as mine is a 4WORK model my rear windows have been de-activated, the switches at the drivers door have been isolated and the switches on the rear doors have a plate welded over them so I thought EASY! I'll just take off the innner panels and operate the switch from underneath. But oh no! not only are the switches welded over from the top but they also removed the whole damn switch as well. I had to take my front passenger door apart as well to borrow the switch and was praying that the wiring was at least still active in the back, luckily it was.
Old May 27, 2007 | 07:24 AM
antlip's Avatar
Default RE: Wind Deflectors
Are thoes in channel visors and where did you find htem?
Old May 27, 2007 | 08:00 AM
zontarh's Avatar
Japanese importOEM (beware of cheap stick-on fakes which don'thave a bracket clippedinto the window frame ridge which will blow off)
Old May 27, 2007 | 09:47 AM
rdenis's Avatar
Nice - seeing them up close has resolved my fear they would give a "cluttered" look. Have you tested them on the M1 yet?
( I was going to ask what effect they have on the back pressure/buffeting issue with rear window down but I dont suppose you wish tobreak your windows to answer! )
Old May 27, 2007 | 11:56 AM
zontarh's Avatar
Only been down the road so far butthe M1 is less than 3 minutes from my house. I met up with the buyer of my steel Outie wheels on the M1 services this morning and did the deal!
Have you never seen these on an Outie before now?
I have an endless supply of photos.
Size:  34.7 KB Name:  2.jpg
Size:  38.0 KB Name:  4.jpg
Old May 27, 2007 | 07:25 PM
spyderco's Avatar
Those deflectors are sick! I have yet to see them on any outie in so cali...but I like it!!! I think I need some...why they gotta be so pricey??
Mo'Money, Mo'Money when you have No'Money...
Old May 27, 2007 | 10:36 PM
BoldlyGoingNowhere's Avatar
Looks great... hey Ill trade my roof rack for your headlight trim and grille.Thats a pretty snazzy work truck.
So on the rubber door gasket you just pull? or is there a special move to it. Do you really notice a difference on wind flow, what about all the way down.
Old May 28, 2007 | 02:42 AM
rdenis's Avatar
ORIGINAL: zontarh
Well then, get on it boy!
I had seen them before but never actually "thought" about how they looked until you started appendaging the "base" work truck Outie. Your spoiler and these trims really look sharp - I've got a dark blue XLS with roof rackso seeing your last pic really helps - even though non-Japanese cars don't have the blind spot/parallel parking mirror I much prefer your mods over the roof rack versions.
Old May 28, 2007 | 01:22 PM
zontarh's Avatar
ORIGINAL: BoldlyGoingNowhere
No need to trade I can let a set of these go for a mere £106, BARGAIN! you even get one for each side included in the price, now I can't say fairer than that!
You need to get a small scewdriver in under the door rubber from the inside to start it off, then just pull it out
Old May 28, 2007 | 10:00 PM
Thanks for the info on the window trim.
Are the light trims OEM? Out of all the non US trims I like that one a lot (so far ) Are they an adhesive trim, or is it a light cover.
Now I just need to start saving up, its 200+ USD (I think) Ill let you know when I get there
