Windshield washer fluid low light
Old Oct 22, 2024 | 09:50 AM
Burke's Avatar
Default Windshield washer fluid low light
is on despite it NOT being low. Local shop says it could cost up to 400.00 if the tank has to come out. If I don’t have it fixed, I can’t reset the “routine maintenance needed” light. So two warning lights come on at every startup.
Old Mar 23, 2025 | 01:58 PM
smithbrown's Avatar
Originally Posted by Burke
is on despite it NOT being low. Local shop says it could cost up to 400.00 if the tank has to come out. If I don’t have it fixed, I can’t reset the “routine maintenance needed” light and other Polaris RZR 800 Accessories. So two warning lights come on at every startup.
The shop is estimating up to $400 because the tank may need to be removed to fix the issue. If you don’t get it fixed, the "routine maintenance needed" light will stay on, and you'll have two warning lights at startup. It's best to get it addressed to avoid further issues, but if the cost is too high, you could consider getting a second opinion or resetting the light yourself temporarily.
Sants04
Jan 22, 2020 12:47 AM
newoutlanderfan
Aug 5, 2010 07:04 PM
nyc95gst
Apr 4, 2007 10:42 AM
Dookitchen
Oct 5, 2006 06:10 PM
Blk95SL
Feb 4, 2006 01:22 PM
