Winter-izing advice
Old Dec 28, 2010 | 12:33 PM
Obakemono's Avatar
Default Winter-izing advice
Hey all, I'll be moving to Denver in a month or so and I needed to run by you guys who live in those cold areas what I should look at and what I should do to my Outie for the cold weather.
I just replaced the battery, I will have new wipers and winter washer fluid, the oil will get changed before I leave Hawaii (5w-20 Mobil 1). Here in a week I will rotate the tires (planning on snow tires when I get there). I was thinking, would a battery blanket help?
Old Dec 28, 2010 | 12:52 PM
ccernst's Avatar
Find some dry silicone spray so the weather strips don't freeze shut. If you don't have a garage...maybe some winter wiper blades.
Old Dec 28, 2010 | 10:04 PM
tcp's Avatar
tcp
Default two things
check your antifreeze's specific gravity to confirm it is good to low temperatures. Should be fine, but you could run a weak solution in Hawaii without having problems. Good thought on the dedicated winter tires. They make a world of difference. Forget the battery blanket. I run my outlander (and every other vehicle i've ever owned) down to -35C without that. As long as your charging system is in good order your battery will be fine on its own.
My condolences on leaving Hawaii for Denver.
Warren
4th Generation
Oct 8, 2012 01:04 PM
Warren
Oct 22, 2005 06:40 PM
NH_3000GT
Nov 15, 2004 01:08 AM
ShadowClouD
Nov 11, 2004 07:29 PM
shamsulaswad
Oct 31, 2004 07:44 PM
