Workshop/User Manual- Download
Old Mar 10, 2023 | 01:47 AM
  #111
shanegtr's Avatar
Just signed up to the forum. Many thanks for the uploads of the repair manuals people!
Old Oct 14, 2023 | 06:01 PM
  #112
whippersnapper's Avatar
I wish someone had the 2021 Outlander Sport service manual. It's nowhere to be found online.
Old Mar 19, 2024 | 03:59 PM
  #113
Aditi's Avatar
Can someone please renew the access or the links?
Unfortunately they are no longer active...
Old Mar 20, 2024 | 08:55 AM
  #114
Unlikely to happen. This forum is pretty dead these days, like most, and there just aren't many car enthusiasts online that own Mitsubishi vehicles. I'll never own one again because information on these vehicles is so scarce online.
Back to Honda/Toyota for me.
Old Feb 11, 2025 | 06:29 AM
  #115
amenotef's Avatar
Yesterday I found this URL with 2017 Workshop Manual in English (this includes 4N14 Diesel Engine). I'd say that I only found 4N14 in two Manuals: 2013 and 2017, not between.
So I'm sharing it.
Note: I do not know the source. So use at own risk (or in a Virtual Machine) since I think it needs admin rights.
To use this in Windows 11 (since I think it is for Windows Vista), you can launch the app from the downloaded zip, then install it, then you go to C:\MITSUBISHI\MUTSW\MUT3\MENU\SCRIPT --> open Command Prompt as Admin in this path --> run start.js --> And the manual should open.
Also, for each image shown in the manual (that has low resolution) I think there is also a PDF with the same name that can be zoomed in without losing quality, these files can be found in the installation folder.
EDIT: it seems the 2017 it installs and execute just fine in Windows 11 without having to do what I mentioned above. I installed first "D:\Mitsubishi ISO\Mitsubishi ISO\17OUTLANDERGF\TOOL\VISTAMSV\InstallMSV.exe" then I opened "SMVCD_KICK.exe" pressed the install option, had to do one restart, then opened again "SMVCD_KICK.exe" pressed install button again, this time started installing things, then I just open the SMV with "Service manual viewer system" desktop shortcut. Since this requires admin rights and the publisher is "Unknown", I did this inside a VMWare just in case.
Anyway, this looks like the same manual here: http://mmc-manuals.ru/manuals/outlan...7/index_M1.htm so downloading it is even more optional.
Irrelevant fact: My Outlander is a 3rd generation 2.2 DID "first facelift" 2014/2015 and looks similar to the one in 2013 manual, but 2013 manual mentions less than 7 liters of Oil engine, and the 2017 manual oil capacity seems similar to mine. So just in case I check both of them).
Old Feb 11, 2025 | 08:01 AM
  #116
So I'm sharing it.
Anyway, this looks like the same manual here: [W/M]OUTLANDER (GF#) so downloading it is even more optional.
Thanks. For those that aren't tech savvy, if it needs admin rights, it's obviously a bad sign, especially for a PDF. Definitely use it in a sandboxed/offline environment if possible.
Old Feb 12, 2025 | 03:43 PM
  #117
amenotef's Avatar
Yes. I just installed mine on a VMWare Windows 11. And actually found out that this 2017 version works fine with Windows 11. Still needs admin rights, one restart, and few steps to install it. But in the end you just click "Service manual viewer system" and it opens just fine.
Toni Abread
Dec 22, 2014 07:17 PM
007Snoopy
Jan 2, 2011 05:09 PM
antlip
Feb 13, 2008 12:26 AM
camion
Jul 8, 2006 09:56 PM
Jewelz
May 19, 2006 04:36 PM
