92 3000gt ls motor swaps and tranny problems
Old Jan 27, 2012 | 06:40 PM
JonnyHurricane's Avatar
Default 92 3000gt ls motor swaps and tranny problems
Hey my name is jonny just rebuilt my tranny and it will not go into reverse. i will be checkin the fluid lvls tho they should be right then i will be checkin shift fork to see if its broken, and then i will check the reverse sensor for being to tight or wrong washers on it. If you can give any better advise on this problem it would help alot! Also im looking to see what motor's i can put into this car without having to dump a ton of money changing to bigger brakes and rotors and stronger motor mounts ext. with stronger motors for a car that will be a fwd only no mater what. I just need to know what motor i can put into it that will keep from the frequent motor knocking spun bearings and such tho i still would like to give a bit more hp to it. I got a 75 shot of nos hocked up tho i will not use it untill i know the motor is set properly for it. Plz give me all the advice you can thank you!
Eazy man
Dec 26, 2012 07:30 AM
silent
Apr 18, 2012 10:20 PM
Shisha_King
Oct 10, 2007 04:10 PM
Stephen
Jun 16, 2004 02:03 AM
kiaspeanut
Apr 15, 2004 04:22 PM
