Car Won't Start Plz Help
I have a 2000 mitsubishi eclipse gt. 2 weeks ago I changed my valve cover gaskets, put everything back together & the car wouldn't start. I couldn't hear a hum or anything from the fuel pump so I changed the fuel pump thinking that was it...come to find out it wasn't. I ended up putting in a new ignition distributor & spark plugs because I didn't have a spark...I have a spark now. & I had to put in a new crankshaft position sensor because my wire was frayed. I checked my timing as well all of my marks are lined up so it's not the timing. Is it possible that my fuel pump relay or fuel injectors are bad. I have pressure at my fuel rail because when I loosen the rail & bump the ignition fuel shoots out. I checked my plugs & they were wet & smelled like gas. My car cranks but it just won't turn over. Plz help I need this fixed ASAP
