Needing help......
Old May 20, 2011 | 12:04 AM
501Desi's Avatar
Cool Needing help......
I just got an 01 galant and discovered that it had the wrong ECM in it so I got a used ECM but now all the car will do is crank over. I am at a stand still with what to do. Any and all advice will be extremely helpful thanks
Old May 20, 2011 | 08:41 AM
how do you know you have the wrong ECM before? And why was it the wrong one. Where did you get this one and do you know it came from a working car?
It could be anything from a bad ECM, bad ground, or a bad fuse. Check to see if you are getting spark to the plugs or fuel to the injectors. Also check if you can hear the fuel pump priming when the key is in the ON position.
Old May 22, 2011 | 10:26 AM
501Desi's Avatar
I looked online and the part number one the one in the car was for an 02 then I looked up my application and got a different part number so I contacted the Mitsubishi dealer and gave them my vin and got the right part number for my car. That's when I tracked down the one I have now.
MotivationDSM
May 8, 2010 09:25 PM
psychoscoot
Sep 3, 2009 11:17 AM
underpressure2003
Aug 25, 2008 06:41 AM
dasd11
Aug 30, 2006 07:48 PM
osubuckeyes
May 31, 2006 02:38 AM
