New alternator(New problem)? 97 GST
Put in new alternator in a 97 GST. Now battery and brake dummy lights flicker. Also headlights and dash lights dim with higher rpm's. Is it a belt problem or a short problem or what?
NEED HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
RE: New alternator(New problem)? 97 GST
This is your first post in the New Members Area?
Anyways, make sure the belt is tight and check your connections at the alternator & battery. A weak or discharged battery can do that until it starts to recover. Try re-charging the battery. Worst case, your new alternator is bad. |
One thing also to check... did you plug the alternator in?
Its something that dumb as it may sound, is consistently overlooked. |
