16G Turbo Oil Return Line
im looking for a 16G Turbo Oil Return Line and everything to install it.....mine leaks...anyone know were i can find a good one
RE: 16G Turbo Oil Return Line
Just about any DSM online shop carries what you're looking for.
As long as you get the "Mitsubishi Turbo" kit. You can also get a steel braided ones too...a little more pricey though, but pretty cool nonetheless, lol.
SBR is kind of high IMO, DSM.com is cheaper (ok, maybe not cheaper, but they do offer a basic kit) http://www.diamondstarmotorsport.com...allparts.shtml look about a quarter of the way down. You can also get a basic line for $50 at DSM.com if you're strapped for cash. Anyway, either is fine. |
i orderd it and i was wondering if i should put a lil silcone on the Machined -10 AN turbo and oil pan fittings .....or just the gasket without silcone...and if i spelled anything wrong....SORRY...Lil bit Tired
No silicone needed on the fittings, unless otherwise suggested from the company you bought it from. I wouldn't put anything on the gasket either, it won't leak unless it's defective, or unless otherwise suggested from the company you bought it from. If so, I'd worry, gaskets should work fine straight out of the box and so should the oil line:D
