28 psi
Old May 23, 2007 | 10:46 AM
2gEclipse96's Avatar
Default 28 psi
28 psi on a stock turbo????? [>:]i met this guy a while back he said he disassembles the turbo does what he needs..............True???
Old May 23, 2007 | 10:49 AM
Dusty Eclipse's Avatar
Default RE: 28 psi
Stock turbo on what??? What heads does he run with this??? It all sounds.... very unlikely.
Old May 23, 2007 | 11:07 AM
Default RE: 28 psi
its a gst not sure what all he has done.........but i don't think its true
Old May 23, 2007 | 11:20 AM
TheAdvocate's Avatar
Default RE: 28 psi
no... The 14b couldnt even do that... not to mention the T25..
Old May 23, 2007 | 11:25 AM
Default RE: 28 psi
thought so
Old May 23, 2007 | 12:04 PM
Default RE: 28 psi
well sure you could try and push that on a t25, but it wouldnt happen for many reasons. First your car will fuel cut before you reach it. Next the turbo wont even hold that at all. It would drop off to like 20psi at best. And the turbo would not last very long. Its all BS.
Old May 23, 2007 | 12:53 PM
Default RE: 28 psi
If you get better compressor wheel etc and basically rebuild the turbo.
TE is right, the drop off would be huge. I had a GT28 and it dropped a little. Not to mention i would never push it past 19psi (daily)
Old May 23, 2007 | 03:33 PM
Default RE: 28 psi
I think the 14b can run low (LOW) 20's being rebuilt... But the T25 is junk and prolly couldnt even get to 20...
Old May 24, 2007 | 09:43 AM
jpmontero98's Avatar
Default RE: 28 psi
idk much about turbos....but isnt it bad for stock engine and 24 PSI?like wouldnt it blow the engine?
Old May 24, 2007 | 10:50 AM
Default RE: 28 psi
There is a vid of a 2g FWD talon with 450whp pushing over 35lb of boost... yet again, it DID blow up on the dyno lol
I wouldnt go over 28psi o nstock internals. Maybe thats what he meant?
