3g eclipse turbo kit
has anyone turbo'd there 3g eclipse i know people on club 3g have but they were not a big help. So basically can anyone explain to me all the parts i will need, or has anyone found a good kit that leaves ntohing out.
o my car is a 2000 GS
pieces you will need? here's what you need for any turbo kit:
manifold
turbo
wastegate
ic piping
fmic
bov
boost gauge
wideband
tuning device (engine management or AFC)
injectors
fuel pump
fuel pressure regulator
and a tune
its a good idea to also buy a clutch b/c if you have a decent turbo on there the stock clutch won't be able to hold for very long. WPSpyder has a very nice turbo'd 3rd gen on here and is currently haveing a bottom end rebuild done to push over 450 i think. he'd be the person to talk to. you can probably find him in the 3rd generation locatinon of the forum. to turbo a non turbo'd car you are looking in the price range of 4k... if you rebuild the bottom end apx 5500 and total engine rebuild as much as 10k..... all depends on how much you wanna run. i've seen pieced tubo kits thrown together for under 2k though.
manifold
turbo
wastegate
ic piping
fmic
bov
boost gauge
wideband
injectors
fuel pump
and a tune
I found a turbo kit for the 3g eclipese they sell it at www.ddynopower.com they should have what you need for around 2 to 3 grand...
that looks like a decent kit that comes with almost everything you need. I would recommend also upgrading the exhaust and the clutch, and a wideband. because the wideband gives you the ability to tune the safc a million times easier. because without it, it's all guess work, and you don't wanna end up blowing something
theironman
Apr 1, 2010 05:57 AM
blitzsuperstar
May 6, 2009 05:12 PM
RCJr9186
Aug 26, 2006 09:31 PM
blitzsuperstar
Aug 21, 2004 07:37 PM
