95 eclipse turbo
Old May 20, 2010 | 09:56 AM
TMACRUNNEL's Avatar
Exclamation 95 eclipse turbo
I need to locate the adapter from turbo 2" od to intercooler 2.5" od. help me out.
Old May 20, 2010 | 09:59 AM
TMACRUNNEL's Avatar
Also, a question for anyone with knowledge of subject. My turbo has 120k miles on it and I heard that just replacing bearings can recover 2 lbs of missing boost.
Old May 20, 2010 | 12:17 PM
what size is the IC piping. I am assuming all you need is the adapter coupling like this http://www.atpturbo.com/mm5/merchant...y_Code=SIL-TRN
Old May 21, 2010 | 10:46 AM
TMACRUNNEL's Avatar
Thumbs up coupler
Thanks. I found a reducer/ coupler for $10 here in town at local turbo shop.
Old May 21, 2010 | 05:30 PM
was it silicone? because those cheap rubber ones will always have problems popping off under boost especially if you only use cheap worm clamps
Old May 24, 2010 | 09:15 AM
TMACRUNNEL's Avatar
Default coupler
Definitely silicone (4 ply). Basically exactly like the item in the link you provided. Yeah, I'd like to see one of those rubber ones after being exposed to 3-400 degrees a few times not to mention issues with the hoses blowing off. You're right good clamps are a must.
blitzsuperstar
May 6, 2009 05:12 PM
Janarris
Dec 14, 2007 04:47 PM
zeanimal2001
1st Generation
Jun 17, 2007 01:12 PM
blitzsuperstar
Aug 21, 2004 07:37 PM
turbotalon95
Jun 29, 2004 02:38 PM
