actuator solenoid
Old May 6, 2007 | 07:40 PM
spyder4g63t's Avatar
Default actuator solenoid
my car is stuttering as i push the gas turbo spoolin but the car is goin no where i was told it was my waste gate actuator solenoid ant info on that....i just got my inserts ...and i was gonna get the greddy profec bc instead of spendin money on the solenoid cause the bc comes with one i was told.....
Old May 7, 2007 | 12:55 AM
Default RE: actuator solenoid
If you ask me i say you have a boost leak. Or the wastegate could be stuck. Get down there and check it out.
Old May 7, 2007 | 06:48 PM
i did but there was no visible damage thats why i took it to the mechanic who then connected it to a computer and drove it at first he said it was my vacume lines so i got those replace and it still wasnt running good when he checked it out he said it was my waste gate solenoid actuator...so this is where i am at right now its runnin like **** and its pissen me off every time i try to accelerate it spools but sputters like pppaaaapppppaaapp < like that :O0 soo he also checked for a leak and there was none...so have you encounterd this or heard of this ...
Old May 7, 2007 | 09:20 PM
sounds like your misfiring to me. I would check the spark plugs and wires
Old May 8, 2007 | 06:57 PM
i did that but themechanic thought it was misfiring but he took out the plug of which he thought was the one and said it still had spark so noone has ever heard of this actuator problem....ill get sum ngk plugs and see if that helps...but all at the same time i changed the plugs wires and vacume lines that why this solenoid is in the equation
Old May 8, 2007 | 07:50 PM
well i guess it could be the wastegate solenoid. Or it might even be the Boost control solenoid. Or it might only be something not lining up in the wastegate causing low boost. I would say get a MBC first to see if its the BCS. If that doesnt fix it then its something in thewastegate
Old May 8, 2007 | 09:11 PM
so do all the electric bc come with the solenoid..thats what i was told and why i came to the conclusion to get the bc instead of the wastegate solenoid itself which cost 100 and up when the bc comes with it
Old May 8, 2007 | 10:15 PM
no a boost controller only gets rid of the BCS, not the actuator
Old May 8, 2007 | 11:53 PM
not tha actuator solenoid? so i have to buy the solenoid which is causing all this mayhem so the mechanic told me wrong....when i went to look at som bc the guy told me that the piece that is bad (actuator solenoid) comes with the bc
SAFC 2 vs dsm link which is better
Old May 9, 2007 | 12:00 AM
you think he ment my bcs is causing this sputerring and poor performance
