bad Crank sensor on a gst??
Old Sep 2, 2009 | 10:45 PM
spyder4g63t's Avatar
Default bad Crank sensor on a gst??
How much would it cost to change a crank sensor on a 97 gst ? Gotta guy askkn 250 .. Good?
Old Sep 4, 2009 | 09:03 AM
oh_what_up's Avatar
Not a bad price for the work involved, but its much cheaper (obviously) if you do it yourself. Its the same procedure as changing the timing belt, except after your remove the timing belt, swap out the sensor before you put everything back together. You might be able to get the crank sensor out without removing the belt, but I wouldn't recommend it.
Rlopez89
Jul 16, 2013 05:21 PM
xslim69
Jan 20, 2007 10:41 PM
WIFES91GTSL
Jun 15, 2006 07:25 PM
WIFES91GTSL
Jun 15, 2006 06:06 PM
ywill9
Mar 15, 2006 03:54 AM
