Blown Turbo
Old Jan 22, 2008 | 02:44 PM
Xavier2k20's Avatar
Default Blown Turbo
I was just wondering how much a turbo would cost me. Iwas thinking about getting a 95 eclipse gsx, stick, but it has a blown turbo, He said it leaks oil which causethe car to smoke. I was wondering How much would a stock turbo cost, or if the price isn't to excessively more, or bigger turbo. But if it requires me to have to spend even more on the engine i can hold off. I want to build the engine over a period of time. And if possiblewhere to getthe turbo your talking. Thanks in advance.
Old Jan 22, 2008 | 02:55 PM
bestwiseguy's Avatar
Default RE: Blown Turbo
You can buy the stock t-25 turbo used for around 125.00 usually. If you want to upgrade to something bigger, you can get an evo3 16g for around 350.00 used usually. But if you get a bigger turbo you will have to do some fuel upgrades as well as a tuning device and gauges. check out dsmtrader.com, you can usually find both these on that site.
Old Jan 22, 2008 | 03:37 PM
Xavier2k20's Avatar
Let say i bought the the 16 turbo, how much would i have to spend on the fuel system and guages. And how much do mechanics charge to put in. My brother in law is a mechanic and said he's never done a turbo before but is sure he can do it. Is it something Extremely hard to do
Old Jan 22, 2008 | 03:44 PM
No its not. and you only need the other stuff if yo uwant to run it at its full potential.
Seriously, a turbo causing a decent oil burn is unlikely.
I recomend doing a compression test on the engine before continuing further.
Old Jan 22, 2008 | 03:52 PM
Xavier2k20's Avatar
according to the guy the turbo started going bad and now the turbo doesnt even give 25% boost anymore and due to the crack in it it spits oil everywhere causing loads of smoke. I want to put some money into the engine but just what i need to get started. Sorry for wasting your time with dump questions.
Old Jan 22, 2008 | 03:59 PM
I would definately get that fixed asap. I agree with sebba though it would be a good idea to get a compression test just to see if the engine is worth building up, if not then what your trying to do is pointless lol.
Old Jan 22, 2008 | 04:02 PM
Xavier2k20's Avatar
just one more question and i'm done. If the engine is bad or if i wanted to go newer. Where could i get a gsx engine from. Websites. What would the engin enumber be
Old Jan 22, 2008 | 04:06 PM
that engine is the 4g63, there are several websites you can get one from including one i posted earlier in this thread. Just do a search on this forum and you will find tons of info and sites. Also look up a 6 bolt block if you do end up getting a new motor.
Old Jan 22, 2008 | 04:11 PM
Xavier2k20's Avatar
thanks so much
Old Jan 22, 2008 | 04:37 PM
anytime man
