boosting way too much!!!!!!!
Old Jan 28, 2008 | 01:57 PM
lhausi2's Avatar
Default boosting way too much!!!!!!!
My car is a 97 gst and for sum reason it boosts all the way to 30 pounds. I tried turning my mbc all the way up and all the way down and it doesn't change. Anyone got a clue what's wrong
Old Jan 28, 2008 | 02:36 PM
atown420's Avatar
Default RE: boosting way too much!!!!!!!
your mbc is probably setup wrong like mine was. i would just take it all the way out and connect the line from the turbo to the wastegate and see if that changes it. do you have your mbc t'd into any lines? the best way is to just put it between the turbo and the wastegate is how i have mine setup. and i dont have any boost spikes. try that.
Old Jan 28, 2008 | 02:52 PM
lhausi2's Avatar
Well I would but there's only a line coming from the wastegate, none from the turbo, I got a big 16g with a td05 housing, if that helps. I know which line you mean and I don't have it. And yeah the mbc was t'd into the gauge first then tried the bov and still the same. Could it be a crappy boost controller?
Old Jan 28, 2008 | 06:46 PM
TheAdvocate's Avatar
Did it just start happening.. Or did you just install the boost controller? If it just started happening could be your wastegate.
Old Jan 28, 2008 | 06:48 PM
Maybe the gauge is wrong....
Old Jan 28, 2008 | 07:09 PM
lhausi2's Avatar
i don't think the gauge is wrong, although I got the greddy one that is in bars, which I hate. but i don't think the gauge is wrong, and yeah i'm going to order a new mbc, and jw how much would a new wastegate be?
Old Jan 28, 2008 | 07:13 PM
Dude... you obviously hooked something up wrong.
Old Jan 28, 2008 | 07:32 PM
lhausi2's Avatar
aight here it goes, wastegate to bottom of mbc and other side tee'd off into the boost gauge(and no it's not that cuz i tried teeing it into the bov too), bov goes into the manifold
Old Jan 28, 2008 | 10:27 PM
lhausi2's Avatar
tonight i slapped in my buddies mbc and once it hit 1.25 bars(roughly 18 psi) it would choke, it was weird
Old Jan 29, 2008 | 06:55 AM
so you dont need my MBC? Somehow to me this seems like your having a problem more with the wastegate. Your on a 16g internal wastegate correct? There is a way to check if its working. I dont remember exactly how but it has to do with the actuator
