can it be done?
Old Sep 9, 2007 | 10:12 PM
jchrisjohn's Avatar
Default can it be done?
I have an 03 eclipse GTS, first car like this I have owned. I want to get up around 300-350 hp what should I do. I am installing Greddy cat back and a nice cold air intake, not sure which. I have made the switch from muscle cars but need help these thing are so diffrent. also can my internals in the engin and drive train support that kind of power, any help I can get thanks.
Old Sep 9, 2007 | 10:19 PM
Default RE: can it be done?
Well the best thing you can do is go forced induction in the form of a turbocharger. You unfortunatly have the GTS and that has super sh!tty pistons. So, if you want to do that then i would suggest changing to forged pistons/rods... then when you do that you will need Greddy E-Manage and injectors and a fuel pump. You will also need a new clutch at that point.. and probably a limited slip differential.... and when your finally done you wont be able to put any of that power down anyway because its front wheel drive.
Have you ever thought about getting a GSX?
Old Sep 10, 2007 | 07:34 AM
Yea sebba is right, with the GTS which is different from the GT because it has more power from stock but unfortunetely they have higher compression pistons which as you should know higher compression is worse for forced induction. And getting to 300WHP is not gonna be easy without FI
Old Sep 10, 2007 | 06:36 PM
jchrisjohn's Avatar
Ok. what is GSX, and so basically it is going to be more money than it is worth, that sucks, my mustangs where so easy to make fast but sick of rear wheel drive cars
Old Sep 10, 2007 | 06:40 PM
Natedogg89's Avatar
ORIGINAL: jchrisjohn
1. GSX's are all wheel drive turbos. Either a 1G or 2G would work, also Talon TSI AWD's are the same thing just a slightly different body style. DSM's are pretty easy/cheap to mod but they do break so take care of it.
2. Yes it would cost more than its worth to get the numbers you want out of your 3G.
Old Sep 10, 2007 | 07:13 PM
jchrisjohn's Avatar
ok, remember I am new so what is a DSM. I realy dont care about drag raceing but I want to go from 20 100mph quick
Old Sep 10, 2007 | 07:21 PM
DSM = Diamond Star Motors. They include all Mitsubishi Eclipses 1990-1999 (1st generation stops at 94) all Eagle Talons 1990-1998 an Plymouth Laser too.
The GSX is basically the all wheel drive model and it the best for modding, purly because of all wheel drive. The GST has the same engine only its front wheel drive.
They are absolutly awesome for modding.
Old Sep 10, 2007 | 09:03 PM
Dusty Eclipse's Avatar
This is all info that could be found using the SEARCH feature of out Forums.
Old Sep 11, 2007 | 04:39 AM
ComposeEvo's Avatar
why did you make the switch? and what year mustang did you own?
Gus
Old Sep 11, 2007 | 06:40 AM
jchrisjohn's Avatar
well I just wanted something diffrent had an 89' and 2- 95' gts and I really like the looks of the 3gs eclipse.
