conversion
Old Jul 29, 2006 | 01:14 AM
DaClipsa's Avatar
Default conversion
im taking the turbo engine out of a 91 talon tsi fwd and putting it in my 94 eclipse gs 2wd. my question is, do i need the wiring harness out of the talon in order to get the engine to run?
Old Jul 29, 2006 | 02:12 AM
Default RE: conversion
you might need to use the ecu from the talon. Not totally sure though
Old Jul 29, 2006 | 07:43 AM
You will need the ECU
Old Jul 29, 2006 | 10:46 AM
slow420a's Avatar
deff need the ecu
Old Jul 29, 2006 | 06:45 PM
importorigins's Avatar
When in doubt if using the engine from another car always use that same wireharness and ecu. Would save a lot of hassle.
Old Jul 29, 2006 | 11:43 PM
patsevo8's Avatar
you wont need the harness and but the ecm.
Old Jul 30, 2006 | 09:04 AM
oldskoolturbo's Avatar
ORIGINAL: importorigins
To true! thats a man speaking from experiance! always use the harness and ecu from the donor engine. if you leave it connected when you take out the engine you may find you can sometimes (not always) just "plug and play"
Old Jul 30, 2006 | 04:50 PM
DaClipsa's Avatar
so the majority of you guys are saying i jus need the ecu, but no wiring harness? correct. thanx for all the input.
Old Jul 31, 2006 | 05:13 AM
Still think you should take both the ecu and wiring harness
TVP
Jun 5, 2005 01:48 PM
TVP
Apr 28, 2005 12:34 PM
KrazeeKaos
Feb 15, 2005 02:27 AM
eclipsegst97
Feb 11, 2005 03:05 PM
x_upjohnson
Dec 31, 2004 01:27 AM
