EVO MR Turbo in a 99 GSX
I recently just purchased a Stock turbo and manifold from a 2005 Evo Mr and i want to put it in my 99 gsx,i know the manifold and turbo will bolt right up because of the 4g63 engine but what do i need to do to make it work properly,injectors,exhaust,fuel pump etc....My car has 59,987 miles on it and i have Forced Performance 3' exhaustSolid CNC Aluminum Motor Mounts and thats about it..Has anyone ever done this, if so please give me some help????
RE: EVO MR Turbo in a 99 GSX
yea but at 15 psi on a bigger turbo your gonna have alot higher air flow. So if you dont plan on upgrading parts then dont plan on really running too much higher than 12psi. But for some mods i think youd want to get is a fuel pump(190lph) I think the stock injectors might be good on that up to like 16psi, but thats just a guess. Your gonna need a front mount if you plan on boosting higher also. Obviously youll need a MBC and guage. Now depending on what you plan for power with it, and boost you want to run, you might want to look into tuning the air/fuel also.
ORIGINAL: Sebba
you can just bolt it up if you want... the only time you need the fuel upgrades is if you want to go over 15psi.
DjCorkscrew
03-20-2006 11:18 PM
