help with a turbo
Old Nov 5, 2005 | 12:11 PM
rm449's Avatar
Default help with a turbo
Hi my name is mark and i just got started into the import seen. i use to race motocross a lot so i know a lot about that. i was wondering if you guys could help me out? i have a 1994 eclipse gs and i was wondering what the best turbo kit would be. i know that you must get forged pistions and rods. but other than that i have no clue so any help would be very usefull
Old Nov 5, 2005 | 12:39 PM
Patrick's Avatar
Administrator
Default RE: help with a turbo
check out the eclispe section, we have several write ups on how to bulk up your engine.
Old Nov 5, 2005 | 04:12 PM
eclipsed4u's Avatar
ORIGINAL: rm449
is your GS a 1.8l or 2.0l?
Old Nov 5, 2005 | 04:14 PM
TheAdvocate's Avatar
I had a GS a couple years ago, and to tell you right out... You would be better off trying to find a GST somewhere... The money your gonna spend on the GS to bulk it up and to put a turbo on it later is gonna get up there in $..
Old Nov 5, 2005 | 05:02 PM
FireDoc's Avatar
If you are going to go ahead with this project, and you are buying pistons, your stock compression is 9.0:1. Get a set of dished pistons so you can crank up the boost. You will be pretty limited to how much pressure you can safely add without killing your reliability. The Advocate is correct though, It will cost you because of your non-turbo config. So unless the car has sentimental value, (as every car in my garage does, I can't help myself) then go for the 4g63T. Her's a site for you. www.slowboyracing.com
aznspyder
25
Nov 28, 2007 04:57 PM
turbotalon95
Jun 29, 2004 02:38 PM
scrappy24
Apr 7, 2004 11:04 PM
GSkiDD
Jan 29, 2004 08:04 AM
Eclipse_GSX
Jul 10, 2003 02:34 PM
