My new FMIC set-up
Old Oct 29, 2007 | 11:14 AM
1ViciousGSX's Avatar
Default My new FMIC set-up
Well my newFMIC is finished. Went with the Garrett/PTE 24x12x4 core. Made everything else.
I don't think anybody would want to fit a bigger core to the front of a 2g. It takes up just about all of the available space, unless you really want to hack up the car/bumper. Although the LICP is 2.5 inches, we jumped it up to 3.0 at the inlet to the core, just in case I ever needed to go bigger it would be as simple as replacing the LICP. The pipes were trimmed to the shape of the tank openings so there would not be any pipe protruding into the tanks. We are running 3.0 inch up to the TB elbow. Still haven't decided which TB I want to go with yet, I'm working on that, but it will be done later. The tanks are made from .090 aluminum. We pressure tested it @ 42psi to make sure the welds would hold and check for leaks. We have engineering templates made for the tank panels that I'll try to scan and post later if anybody wants them. We cut the lower part off the bumper support brackets to make room for the intercooler pipes as seen in the pics. Everything will fit under the bumper and retain the driving/fog lamps. We had to trim back the bumper to clear the inlet/outlet pipes and make room for the thicker intercooler. If you look in the side vent openings you can see where we trimmed the top of the openings to clear the pipes. Came out very well. Now I just need to decide on a throttle body.
[IMG]local://upfiles/13581/942D1C0A62DE4E0380ACEE6B6663B375.jpg[/IMG]
[IMG]local://upfiles/13581/5F1091144E0D46689E4CC1C20BBE4A3F.jpg[/IMG]
[IMG]local://upfiles/13581/6CB02EA6728A4B6090E051D961095E60.jpg[/IMG]
[IMG]local://upfiles/13581/624B19B6B0DD457BBEA51F04D7860D67.jpg[/IMG]
[IMG]local://upfiles/13581/F0273868333140FAAFBBEBD16902157E.jpg[/IMG]
Old Oct 29, 2007 | 11:18 AM
Default RE: My new FMIC set-up
More pics
[IMG]local://upfiles/13581/FCBDFAAF523D43D686AEE5321DFF0E6C.jpg[/IMG]
[IMG]local://upfiles/13581/C40A610774CA438DA508C31250C1E084.jpg[/IMG]
[IMG]local://upfiles/13581/E97FCFBA16184C5D89A004F5D910C2FF.jpg[/IMG]
[IMG]local://upfiles/13581/673245B068E84747A829512315AD7102.jpg[/IMG]
[IMG]local://upfiles/13581/B4B49963C35844FB8074DAB8664CB5CF.jpg[/IMG]
Old Oct 29, 2007 | 11:21 AM
The way we installed the intercooler was to butt it up very close to the underside of the bumper support with plenty of clearance in front of it. This makes a high pressure area while the car is moving which will push air through the upper part of the intercooler that is not visable from the front. Added the Tial 50mm BOV.
[IMG]local://upfiles/13581/427EFF11910C46BD8CBC4496E1A33E35.jpg[/IMG]
[IMG]local://upfiles/13581/7C93121E80A242BB873F3B7C4B35ADC2.jpg[/IMG]
[IMG]local://upfiles/13581/603EAEC28F284EDE9260E569D09E7916.jpg[/IMG]
[IMG]local://upfiles/13581/33362DF0D05E4EE5AD94D6C8C85D24C9.jpg[/IMG]
[IMG]local://upfiles/13581/CE9345A573AB4D48AD63D2AE0D3B3735.jpg[/IMG]
Old Oct 29, 2007 | 12:32 PM
dsm1990gsx's Avatar
Wow that thing is huge, looks very nice how it sits behind the bumper cover. Nice job.
Old Oct 29, 2007 | 12:50 PM
very nice. What turbo are you running. And with this type of setup i would just get rid of the whole MAF translator system and go right to AEM
Old Oct 29, 2007 | 12:56 PM
ORIGINAL: TheEngineer
Innovative Turbo System's version of a T67/p-trim/t3 .82.
We have emissions testing here in Louisiana so an AEM is not part of the current plan. Got to get thoses inspection stickers.
Old Oct 29, 2007 | 03:51 PM
Thats bad *** man.
Old Oct 29, 2007 | 06:16 PM
TheAdvocate's Avatar
Im surprised that front bumper fit bak on there..
Looks impressive!
Old Oct 31, 2007 | 01:09 AM
sk8dudety's Avatar
very nice! looks good man, keeps gettin better!
Old Dec 26, 2007 | 11:46 AM
tcobb01's Avatar
hey i just bought my gst and i just got an oil change mobile 1 syntheic oil do u have to change the stock turbo after 100,000 miles ?? it doesnt lag or anything it boost right up everytime..i just dnt want it to hurt my car if it does need changing can u pls tell me ?? thanks !!
