small 16g
RE: small 16g
OK in order to run more than 12PSI and not pull timing you you will needa fuel pump and injectors and have it tuned. It is basically a direct bolt up only needs the install kit and it will work on the stock exhaust manifold.
Max output of the S16G is 350WHP or something in there that is at about 21PSI and you will need all supporting mods for it (fuel pump,FPR,injectors, GOOD tune, full exhaust 3in turbo back, intake,FMIC and piping,BOV ect ect ect.
millie
01-02-2006 05:08 PM
