smoke from exhaust and burning up lots of oil
Old Feb 19, 2010 | 09:04 AM
Way to copy my post lol. At least you're relaying accurate information.
Old Feb 25, 2010 | 05:19 AM
trainy's Avatar
I said, don't know how your set-up is but if you like most, I have like a flex-hose running from air cleaner set-up to turbo's "mouth". If you look in yours Im positive you'll find your turbo's "mouth" is spitting up oil, probably whole bunches in there. Now, part of the smoke problem is the car warming up, contributing, burning all that oil in your hose too that's really not suppose to be there. Your turbo runneth over, need to replace gasket, rebuild, turbo.
Old Feb 25, 2010 | 10:47 PM
disguy2k's Avatar
Engine smoke only at idle usually will be leaking valve stem seals. This will happen when the motor starts getting a bit tired. (usually starts appearing after about 80k miles)
The other causes discussed previously in this thread will only usually happen when you are on boost, or standstill to heavy acceleration, and you will see smoke on even relatively new cars.
cdvyas20
Feb 19, 2013 06:24 PM
mirage1.8
Aug 5, 2011 05:52 PM
EMonz57
May 14, 2008 08:45 PM
DragonRacerX666
Jan 30, 2007 12:47 AM
vickfalcons78
Jun 23, 2006 11:30 AM
