SOHC 6G72 turbo?
has anyone done a turbo upgrade to the 3L SOHC V6? from what i understand it should work if you can get teh parts. it has 8.8:1 comp already, and all you would need is the turbo, some parts and ECU. i was thinking of this cause my duster has the base 3L engine with only 145hp, and i would like alittle more top end :-D. thanks
No. The 3000GT I believe is DOHC 6G72. It is the same motor as in a 3G Eclipse or 8G Galant....
http://www.galantforums.com/modules....album=13&pos=0
That is a tearstone kit in a 6G72 3G Eclipse SOHC.
that has a different intake than mine, and i believe the turbo only runs off of half the exhaust, its positioned to run off the crossover pipe, so cyl 1,3,5 only. my intake is centered over teh engine so teh piping would be a different and harder to do smoothly
ORIGINAL: Prophet
ORIGINAL: Shadowplane676
