SOHC 6G72 turbo?
Old Oct 5, 2005 | 02:18 PM
Shadowplane676's Avatar
Default SOHC 6G72 turbo?
has anyone done a turbo upgrade to the 3L SOHC V6? from what i understand it should work if you can get teh parts. it has 8.8:1 comp already, and all you would need is the turbo, some parts and ECU. i was thinking of this cause my duster has the base 3L engine with only 145hp, and i would like alittle more top end :-D. thanks
Old Oct 5, 2005 | 03:50 PM
eclipsed4u's Avatar
Default RE: SOHC 6G72 turbo?
what is the engine code for that engine?
Old Oct 30, 2005 | 07:48 PM
engine is the SOHC distributed FWD 6G72
Old Oct 31, 2005 | 12:56 AM
eclipsed4u's Avatar
is this the engine out of the base model 3000GT?
Old Oct 31, 2005 | 01:14 AM
Prophet's Avatar
No. The 3000GT I believe is DOHC 6G72. It is the same motor as in a 3G Eclipse or 8G Galant....
http://www.galantforums.com/modules....album=13&pos=0
That is a tearstone kit in a 6G72 3G Eclipse SOHC.
Old Oct 31, 2005 | 03:08 AM
that has a different intake than mine, and i believe the turbo only runs off of half the exhaust, its positioned to run off the crossover pipe, so cyl 1,3,5 only. my intake is centered over teh engine so teh piping would be a different and harder to do smoothly
Old Oct 31, 2005 | 10:45 AM
eclipsed4u's Avatar
ORIGINAL: Prophet
i *think* the 3000GT came with a base model 6G72 SOHC 145hp engine and the 6G72TT vr4 engine. i know its not the same as the 3G v6 because of what i have highlighted in his first post.
ORIGINAL: Shadowplane676
Old Oct 31, 2005 | 10:46 AM
eclipsed4u's Avatar
can you tell us what year and model car you have?
Old Oct 31, 2005 | 05:17 PM
the car is a 1992 plymouth sundance duster 3L v6 5sp, FWD
Old Nov 29, 2005 | 01:25 PM
Blue03Evo's Avatar
i fabricated my own turbo kit on my old 3rd gen 6G72. what do you want to know?????? i should be able to help somewhat
