stock turbo settings
RE: stock turbo settings
Search button would tell you we talk about this a bunch of times.
stock t25 turbo runs 8-12PSI they can only handle 16PSI 17PSI tops the turbo is not that great and the fuel system is maxxed out at 17PSI.
Do the "free mods" first. Remove your BCS restrictor and that will bring you up 1-2 psi (possibly more). I suggest you do a lot of research on your motor before turning up the boost past what the stock system can handle. I wouldn't even turn it up to the max just to leave a "safety" window for the motor. That's just me though
