stock turbo settings
Old Jan 2, 2007 | 03:24 PM
turbokid's Avatar
Default stock turbo settings
what are the stock turbo setting or presets on a 95 mitsubishi eclipse gst
and wat can they push without blowin up
Old Jan 2, 2007 | 04:01 PM
Default RE: stock turbo settings
Search button would tell you we talk about this a bunch of times.
stock t25 turbo runs 8-12PSI they can only handle 16PSI 17PSI tops the turbo is not that great and the fuel system is maxxed out at 17PSI.
Old Jan 2, 2007 | 06:38 PM
turbokid's Avatar
thanks so wat can i safely turn up my boost to without blowing the side mount intercooler or turbo and have it run nice
Old Jan 2, 2007 | 07:07 PM
paintballproam's Avatar
15-17psi. Stick with 15psi and you will be fine
Old Jan 2, 2007 | 07:44 PM
ORIGINAL: paintballproam
yup
Old Jan 2, 2007 | 08:43 PM
turbokid's Avatar
thanks u guys wat is the easy way to turn it up and if i do will i have a grip probelm
Old Jan 2, 2007 | 08:45 PM
a mbc (manual boost controller) and a boost gauge. DO NOT try to change the boost with out a boost gauge(and i dont mean the stock one)
Old Jan 2, 2007 | 08:47 PM
turbokid's Avatar
will have a traction problem if i turn it up
Old Jan 2, 2007 | 08:55 PM
silvercoupe97's Avatar
Do the "free mods" first. Remove your BCS restrictor and that will bring you up 1-2 psi (possibly more). I suggest you do a lot of research on your motor before turning up the boost past what the stock system can handle. I wouldn't even turn it up to the max just to leave a "safety" window for the motor. That's just me though
Old Jan 2, 2007 | 09:59 PM
turbokid's Avatar
so how to i remove that and were is it located
