Thrust Bearing..HELP PLEASE
Old Nov 18, 2006 | 02:35 PM
jlh077464's Avatar
Default Thrust Bearing..HELP PLEASE
Got a ?.......Well my friend has a 7bolt 4g63t with a act 2600 clutch....he totally rebuilt this engine when he spun a rod bearing and run it for about 1,000 miles and just recently removed his engine and all components 2 have the engine bay sprayed...when we got it out we took the oil pan off just to check how the crank was holding up and 2 his suprise there is a lot of play in the crank....and on the clutch side of the thrust bearing its just not there...its been worn off but the other side is just fine so what can we do?.....i've crankwalked an engine before and we wanna do anything and everything 2 prevent this from happening until he gets tha money 2 do a 6-bolt swap?...any ideas?
Old Nov 18, 2006 | 06:17 PM
spyder4g63t's Avatar
Default RE: Thrust Bearing..HELP PLEASE
no way to prevent that its gonna happen
Old Nov 18, 2006 | 08:43 PM
jlh077464's Avatar
I see.....Well is there any way 2 buy some time until he get the money for the 6-bolt?...if there is another thread that answers this im really sorry..ive just read until my eyes are bleeding..lol....Thanx again!
Old Nov 19, 2006 | 10:18 AM
jlh077464's Avatar
Anything?....and why did it only wear on the clutch side?
Old Nov 20, 2006 | 11:28 AM
because the clutch is one of the contributors to it. Remove the clutch sensor that is used to start the car so that you can do a clutchless start, because that is one of the worse things for it, so that should buy you some time. I think you could replace the bearings with something alittle stronger and that might help it a bit.
Old Nov 20, 2006 | 06:26 PM
jlh077464's Avatar
Thanx for the info....Also do you think we should remove the oil squirters ?.....if so do you simply remove them?...or do you block them off somehow?
Old Nov 21, 2006 | 01:48 AM
well i know magnus motorsports said that they simple machined the block a bit to make it accept a 1g oil squirter and then blocked off the 2g passage. So if you feel like taking the block apart to do it, then it might be another way to increase the time to failure
Old Nov 21, 2006 | 09:30 AM
jlh077464's Avatar
Yea I read that somewhere.....I suggested that 2 my buddy...but see we don't have very trustworthy machinest around here...they will do a halfa$$ job and charge you double and he seems 2 be running a lil low on cash....I just wonder if it's possible just take take them out and be done?....
Old Nov 21, 2006 | 11:31 AM
well those are used to cool the underside of the piston right. So under normal conditions i guess its not bad, but once the engine starts getting under boost i think it becomes important to have. But blocking it off definetly would help the crankwalk situation anyway.
Old Nov 23, 2006 | 02:38 PM
DixonsGst's Avatar
how do you remove the clutch sensor to start the car without having the clutch pressed down? Where is it located? I know its on the steering colum just havent tore it off yet.
Dafatboy
Jul 14, 2015 06:06 PM
KaiserEclipse
Jun 10, 2010 01:21 PM
KaiserEclipse
Dec 9, 2009 02:44 AM
ejmonkey3
Aug 10, 2009 08:33 PM
99clipsgst
Mar 18, 2009 05:21 PM
