turbo 420a
Old May 4, 2007 | 06:22 AM
  #21
TotalEclipse's Avatar
Default RE: turbo 420a
I do love beer.
Old May 4, 2007 | 09:42 AM
  #22
i guess 2.5" would be fine for an exhuast. What comes in this kit thats for sale. And where did the person buy it. Because if its a cheap ebay kit, you may be getting ripped of at 1k
Old May 6, 2007 | 07:43 AM
  #23
This is what the guy posted just wish he would answer...
Garrett T3 turbo 1k miles no shaftplay-internal wastegate at 8psi
Manifold
Downpipes
Rc 510 injectors
FMU
Missing Link
OBX intercooler-its about 3"thick, well over 1 foot tall and almost 3ft long...thing is HUGE!
BOV
Oil line
Water lines
Walbro Fuel pump
Vaccum lines
all bolts and clamps
Old May 6, 2007 | 10:33 AM
  #24
i dont know it id trust it.
Old May 7, 2007 | 09:19 PM
  #25
black_eclipse's Avatar
Does it would run fine with 8psi? i was thinking on 6psi, then, putting some more when i get the pistons.
Old May 7, 2007 | 09:22 PM
  #26
i guess as long as you stay at low psi you should be fine. I would just be very cautious and make sure you do a safe tune
Old May 7, 2007 | 09:24 PM
  #27
ok, thank you. I'll post some pics later and let you know what happend.
Old May 13, 2007 | 04:58 PM
  #28
import tuner's Avatar
black, you really need to take into consideration, about how many miles are on your stock motor? im not trying to discourage you in any way, because im redoing an entire motor from ground up to take a turbo. however on a high miles motor that is very well known for tearing up timing belts and bending valves it is risky. not to mention once you start boosting it theres a good chance you will blow your head gasket. i know the key is in your wastegate. that controls the actual pressure allowed into the motor. as long as thats right it doesn't matter how big your turbo is you are getting a set pressure. try it out but learn from your mistakes. you will find the right combination it just takes time.
Old May 14, 2007 | 12:20 AM
  #29
I know, i'm going to change my head gasket, i got the car with 40,000 miles and i have take a lot of careof it,(synthetic oil every 3,000), i check everything every 2 weeks and i just have 60,000 milesin it right now.
theironman
Apr 1, 2010 05:57 AM
halfasss101
Sep 4, 2007 02:35 PM
Eclipse
Sep 29, 2004 01:18 PM
LowCloud
Jan 5, 2004 05:25 AM
kdombrovski
Jul 10, 2003 02:49 PM
