TurboXS Conversion Boost Controller "Problem"
Old Feb 3, 2007 | 02:39 AM
50ul }{4ck3r's Avatar
Default TurboXS Conversion Boost Controller "Problem"
ok here it is...so ok...The Conversion Boost Controller (BC-CBC) let you turn your single stage Standard Boost Controller (BC-SBC) into a Dual Stage Boost Controller....so when i flip the switch in my car for the Dual Stage Boost Controller (16psi).....it goes good for a lil....and about 5000 rpms in second gear and through the rest of the gears it like bogs out.....but with the switch off...my car runs fine (10psi)......
any ones help will be ...thanx
Old Feb 3, 2007 | 05:11 AM
Default RE: TurboXS Conversion Boost Controller "Problem"
What turbo do you have?
Old Feb 3, 2007 | 05:19 AM
a ported 16g turbo...its the one on the right
[IMG]local://upfiles/10926/065809F9F25A4845B174D06BB68A7E2D.jpg[/IMG]
Old Feb 5, 2007 | 12:56 PM
any one
Old Feb 5, 2007 | 01:33 PM
You probably dont have it tuned correctly to handle that boost. That was the problem i said with the dual stage before is that sure you can change the boost that easily, but at different boost levels it requires different tuning.
jaday
Jul 13, 2006 03:56 PM
04scooby
Feb 10, 2006 04:02 AM
1turbozx3
Dec 24, 2004 04:38 AM
Knaackers
Jul 17, 2004 08:55 PM
Knaackers
Jul 13, 2004 04:16 PM
